'98 Exhaust bracket ID
Old Mar 12, 2020 | 12:36 AM
1997Triton's Avatar
98 F150 XLT 5.4L 4x4 E4OD trans. Working on replacing the drivers side cat/downpipe and the bolt that holds the pipe to the transmission bracket snapped (has the orange silicon isolator in it). I dropped the trans crossmember and mount out and it appears this part is an entire bracket that bolts inbetween the trans and the trans mount. Anyone know the part # for this? Really don't want to hassle with drilling it out if I don't have to. Dealt with enough rusted stuff on this truck and rather go new while it's out.
Old Mar 22, 2020 | 01:29 AM
1997Triton's Avatar
Couldn't find the bracket (or part #) so I just cut off the welded nut from the existing bracket and used a new SS bolt/nut to clamp the exhaust brace down. Works good as new. Fired it up tonight and no movement in the exhaust system so the manifold bolts should live on.
