will they swap???
Old Dec 31, 2019 | 03:06 PM
enriched's Avatar
Arrow will they swap???
Ok I got a wrecked 2001 crew cab, (aka the donor) , mostly for the engine and trans and maybe a few other trinkets.
I have a 2002 super cab , both have 5.4 and auto trans and electric T-case.
Its the other things / trinkets I'm inquiring about. Once home I noticed that "the donor" had power pedal adjustments. bonus #1.
The other thing is that the donor had was "auto on headlights" bonus #2.
What all would have to swap to the my current unit, the 2002, to get the power pedals and or the Auto headlights to work?? maybe it can't be done??
Old Dec 31, 2019 | 03:56 PM
jimbo74's Avatar
5 Year Member
Can probably swap just fine without too much headache. You may need to move some wiring stuffs around though
Old Dec 31, 2019 | 06:18 PM
enriched's Avatar
I was hoping for that ...you wouldn't happen to know what all would need to be swapped wiring wise??
Old Jan 6, 2020 | 04:30 PM
Stoned Pony1's Avatar
Get your ford shop book out and see if your truck has the below hookups in the wiring harness.
Can't think off the top of my head the number on the wiring harness.
Also look and see if the mounts are there for power pump to hook your assy to.
You may have to take every thing out of the other truck to place in yours.
Look under the dash and look above for a pigtail connector that the power pedal hooks to and the power lights have a hookup as well in the harness. You do have to change a few things as the wiring part comes from the donor with power pump.
