Running rough
Running rough
I have a unique problem happening to my F-150 4.6L Supercab, for the past 2 weeks it has been stumbling on acceleration and running rough. I thought it might be the gas because no engine codes were thrown, and added some Heat gas injector cleaner. Then it ran fairly well for about 2 days, then yesterday it started running rough, and threw a code of a misfire on cylinder 4. I changed the fuel filter out, and checked the fuel pressure was 30 psi at idle (low end of fuel pressure). Could it be a fuel injector clogged or no longer working because no codes have been thrown, and usually on a misfire a code is sent almost immediately.
Any help would be appreciated. I have 185,000 miles, and changed the plugs and wires out at 162,000. Is this a sign that a cylinder is going bad?
I was going to pull the plug for the #4 cylinder tonight, and see how it looked.
I recommend removing all the plugs, doing a compression test and installing new Motorcraft plugs and coils.
You can either rent a compression tester from your local parts store, or buy one. The Harbur Frought has them in the auto isle.
Good luck.
Good luck.
So I checked the #4 cylinder, and the plug looked fine, and the fuel injector ohms were in spec. Was going to check each fuel injector with a screw driver to listen to them clicking. Also, was going to add some BG 44K, and see how it runs.
