2000 f150 jerking/bucking
Old Feb 6, 2019 | 04:31 PM
Jrvarga77's Avatar
I have a 2000 f150 5spd idles good no engine shake no engine light, but when i start driving about 10 miles an hr it jerks alot ai i put clutch in jrking stops . Have trouble figuring out what could cause this. Need help. Motor is 4.2 v6 manual transmission
Old Feb 6, 2019 | 05:40 PM
Spark plugs, plug wires, coil.
Old Feb 6, 2019 | 10:00 PM
Bluegrass's Avatar
Supply the following info'
1.Does this happen in first gear at 10 mph?
2. Does it happen in 4th gear at 10 mph?
3. Does this happen at higher speeds over 40 mph?
Old Feb 7, 2019 | 05:52 AM
Jrvarga77's Avatar
around 2nd gear
Old Feb 7, 2019 | 10:38 AM
Bluegrass's Avatar
There could be some issue but overall 10 mph in second is inviting the jerking you experience.
The whole drive train clearance gets to lashing back and forth.
Once you disengage the drive train it goes away.
Check for driveshaft cross joint slop, rear ring to pinion excessive clearance, engine and trans broken mounts etc.
All these add up over time and can cause the issue you have.
Good luck.
Old Feb 7, 2019 | 11:21 AM
My similarly equipped truck doesn't buck in 10 mph in 2nd gear - in fact I can easily start off in 2nd.
I think it's ignition related. How many miles are on your plugs, wires, and coil? What brand are the plugs and wires?
