ECU swap help
Old Aug 25, 2018 | 03:44 PM
Bryan Romero's Avatar
ECU swap help
I have a 2000 ford f-150 XLT with a 4.6 would I be able to use the Pcm off of a 1998 ford f-150 with a 5.4 both trucks have trtions
Originally Posted by Srinath
Oh I have a 97 with a dead ECU, Did a 98 one work ?
I'll do this tomorrow.
question does anyone know if the Pcm from a 98 with a 5.4 will work in a 2000 with a 4.6
I need help I have a 1998 donor truck will the Pcm from that ruck work with the engine from my 2000
Old Aug 29, 2018 | 10:42 PM
I started your own thread instead of hijacking old threads from 2015
good luck with your project swap
Old Aug 29, 2018 | 11:21 PM
No, it will not. You need a 99-03 with either V-8 and 4R70W transmission.
Old Sep 4, 2018 | 11:23 AM
ok another question a friend of mine said you can bypass the pats system with a resistor is this true?
Old Sep 4, 2018 | 12:26 PM
projectSHO89's Avatar
This isn't a GM product.
