Cat. Converter question?
Old May 5, 2018 | 12:37 PM
wdrdoctor's Avatar
Does anyone know out of the 2 front cats,or the 2 rear cats ,which ones are the most restrictive,or all they all just as equally restrictive?
Old May 5, 2018 | 12:52 PM
jimbo74's Avatar
5 Year Member
Old May 5, 2018 | 01:03 PM
wdrdoctor's Avatar
Yes 4 cats on my 2000 f150 4.6 v8 4x2.
Old May 5, 2018 | 02:04 PM
jimbo74's Avatar
5 Year Member
today's cats really aren't that restrictive, they are all pretty high flow
do you have an issue with yours? or are you just trying to eliminate them?
Old May 5, 2018 | 02:33 PM
wdrdoctor's Avatar
It's hard for me to believe it when you say that the cats on an almost 20 yr old truck are not restrictive. I've seen the honeycomb mesh inside the cats ,and if you think that is free flowing and not restrictive is confusing to me. You said "todays vehicles" . A 2000 truck is 18 yrs old ,and isn't classified as one of "todays vehicles".
Old May 5, 2018 | 03:35 PM
Skylardog123's Avatar
All 4 cats are the same, but getting rid if the 1st set of cats or the rears would be more recommended,
Old May 5, 2018 | 03:40 PM
wdrdoctor's Avatar
Here is a pic I found online. for 97 through 2003 exhaust systems with cats and where their 02 sensors are located. So with this what would be the best way to go?
Old May 7, 2018 | 05:40 PM
JDStrickland's Avatar
If your CATs are not damaged, they are not restricting anything. Now, if you were looking to get 850hp at 12,500rpm, the CATs might present you with issues of airflow that you would reasonably want to solve. But if you are driving your truck down the interstate at 80 (because nobody does 65), then your CATs are not a problem unless they are damaged. The CATs are bigger than the exhaust pipes precisely to keep them from constricting airflow.
