Hub assembly bolts
Old Jan 2, 2018 | 06:46 PM
defective's Avatar
Hub assembly bolts
Is there a specific bolt that should be used to replace the ones holding the wheel hub assemblies to the knuckles?
1999 f150 4x4
Old Jan 2, 2018 | 08:44 PM
JCR 56's Avatar
I reused my old ones.
Old Jan 2, 2018 | 09:24 PM
Roadie's Avatar
So did I.
Old Jan 2, 2018 | 10:42 PM
If you need new ones, get them from the dealer.
Old Jan 3, 2018 | 02:18 PM
defective's Avatar
I've reused them before also, thanks but I need to replace them.
One was missing, and another is getting a little worn and I don't want to put it on and not be able to get it off next time.
I'll try giving the dealership a call and see what they say.
Old Jan 7, 2018 | 08:43 PM
defective's Avatar
Found they are ford part number n808718s439.
I used Dorman 917-517. Not specifically for the f150, or Ford. Think it's actually for Dodge. Anyway, it's longer. I ended up cutting it down after installing but it seems to work fine. I reused the other two bolts despite the heads being slightly messed up.
