New key ignition cylinder
Old Dec 1, 2017 | 12:03 PM
CaptainRon60's Avatar
I purchased a new key ignition cylinder for my 1999 Ford F150. It came with two keys. Can I simply remove the old cylinder and replace it with the new, without re-coding anything? That is, I'm assuming the keys that came with the cylinder are already coded. Thanks
Old Dec 1, 2017 | 01:57 PM
New PATS keys always have to be coded to your PCM.
Old Dec 1, 2017 | 03:20 PM
projectSHO89's Avatar
Unless you have a previously valid key for the system that can be "re-purposed", you will need to re-program the PATS system to the new keys.
