No high beams or high beam indicator for a month
Old Dec 26, 2016 | 10:10 PM
FLFordF150's Avatar
I had no high beams or high beam indicator. I figured it was the switch. In the 2001 F150 the 20 amp fuse in slot 16 is loose and even falls out. Jiggling the fuse I gained high beams and high beam indicator again.
I tried lodging a toothpick beside it and doesn't do a real good job holding fuse but helps. Any tricks for a damaged fuse slot?? Tape on fuse to make it wider? Any suggestions besides replacing whole interior cab fuse box??
Old Dec 27, 2016 | 05:26 PM
Disconnect the battery, take a small hook and see if you can bend the metal tab towards the inside of the fuse slot
Old Dec 27, 2016 | 06:10 PM
FLFordF150's Avatar
I couldn't even get test light to light up by pushing in or touching tabs with fuse in.
Old Dec 29, 2016 | 09:50 PM
FLFordF150's Avatar
I'll try that when I get a minute.thanks.
