02 f 150 odd all brake rotor.
I have a 2002 f150 7700 4x4 ext cab lariet 5.4 l with anti lock. 7 bolt wheels
problem is rotor on one side is different than the other .The hub that the studs are pressed into is both thcker and larger in diameter.The rotor fits stud pattern but will not go on one very far before the inner baking suface hits over sized hub.
97-99 f 250 ld 7 bolt is same part, all other years of 7 bolt seem to be same part # but it only fits one side. Truck appears to be original and untouched just did lower ball joints tie rod ends ,caliper is the same .Had it since 06,awsome truck still like knew in and out but cant drive with no brakes.anyone have a clue? I'm stumped so are the dealers. Any help woud sure be appreciated.thnx
