Brake Line Order at HCU
Quick question for those who know...
1999 F150 4-wheel drive, 4-wheel disc, 4-wheel ABS
Changing all the brake lines and as soon as I snipped them off at the HCU, I began to doubt my memory. Which line goes into which port on the HCU?
There's the two lines from the master cylinder on each outside port. Then there's the three ports in the middle. I know the front left brake line goes into the port on the left side (facing the front of the truck).
That leaves the lines for the front right and the rear. Which one goes in the middle?
Thanks to anyone who can put my old (and apparently fading) mind at ease.
Middle one connects the HCU to the front right, passenger's side (from left to right: 1 master cylinder, 2 driver's side front, 3 passenger side front, 4 rear, 5 master cylinder).
The nut at the HCU is 9/16-18, the nut at the brake hose that goes to the front right caliper is a 3/8-24, both ends inverted. The line size is 3/16 in diameter.
Good luck!
Good luck!
