Having Timing Cover Issues on my 98 f150 4.6
Old Aug 9, 2016 | 08:10 AM
Jason Coble's Avatar
Doing some head work got everything replaced and lined up.I then started to put timing cover back on going by bolt diagram
I then started to torque bolts down didn't even get the first bolt tightened and I heard a loud pop and noticed around crank opening in cover it had cracked not sure what made it do it but I dont want to crack another one.Any help would be awesome.
Old Aug 9, 2016 | 12:19 PM
Bluegrass's Avatar
You just committed a basic mistake.
Make sure it's seated against the block all the way around before tightening any bolts.
If it does not find out why.
What else would you do?
Good luck.
Old Aug 10, 2016 | 02:05 AM
JayMods's Avatar
After checking timing components all were good.When i ordered kit the new crank gear was only thing different it was both gears that didn't come apart and it was a little thicker.Unlike the factory one which came apart.Sry I did snug cover to block thought I put that in there
You can see crack here a little better.Can this be welded or repaired .Ordered new cover already just curious
Old Aug 11, 2016 | 12:07 PM
ishootstuff's Avatar
I would look very carefully at the timing chains, guides and gears. That cover was NOT seated against the block when you tightened. That's the only way you could have cracked it.
Yes, you could drill the end of the crack and TIG the cover you wanted. You would have to file down the bottom of the weld bead as it's a gasket surface.
