2002 F150 Tire Size?
Old Jul 7, 2016 | 09:54 PM
Ryan Sandy's Avatar
Hey All!
I have a 2002 Extended Cab Short bed 4x4, Stock wheels and tire size. I as wondering what the biggest tire size I could run with stock wheels with no lift? Also what about with this leveling kit? Says 33 by 12.50 but says not with stock wheels... Please let me know! thanks!https://www.amazon.com/Rough-Country...+f150+lift+kit
Attached Thumbnails 2002 F150 Tire Size?-screen-shot-2016-07-07-9.40.12-pm.png   2002 F150 Tire Size?-snapchat-5845545506499060861.jpg   2002 F150 Tire Size?-my-truck.jpg
Old Jul 7, 2016 | 10:39 PM
Roadie's Avatar
I've seen trucks our vintage with 285/70x17 tires on the stock wheels. That is the largest that the stock rim meets the minimum recommended width.
Old Jul 10, 2016 | 05:00 PM
OhioLariat's Avatar
... and is the size I ran on my '99 with factory 17" wheels. No lift, just tightened torsion bars.
Andy
Old Sep 16, 2017 | 06:33 PM
Bluegrass's Avatar
Behind the top area of the passenger side kick panel.
Its in your owner manual.
Good luck.
Old Sep 17, 2017 | 09:16 AM
Roadie's Avatar
Good luck.
You did what I did on another thread. I scrolled down too far and replied to the "related thread" rather than the one I intended to respond to.
Old Sep 17, 2017 | 10:02 AM
Bluegrass's Avatar
I used the Reply button on the bottom bar to reply.
They either need to fix this or get rid of it.
The add on is of no value.
Second time this has happened.
I will no longer reply on this board until something is changed.
Good luck.
Old Sep 18, 2017 | 04:03 PM
abgarza's Avatar
That's what I'm running with Achilles Desert Hawks on stock rims. Small rub on full turn backing up. My upper and lower control arms are moog and less than 5 months old.
Suspension setup is stock.
