pulsing when braking
Just had 4 new tire installed and alignment done, still getting the ABS light, and a pulsing when braking, like a tire is out of round, but drives nice at all speeds with no pulsing
Are your rotors warped? Have you checked to see if you have a failing abs sensor?
I'm not sure if you were posting a question or a statement, but if it rides fine and only pulses when braking, you should be looking into the brake system.
No vehicle information so there isnt a whole lot to go on but my experience with simular issues is 1 warped front rotors caused by 2 non functioning or barely functioning rear brakes. Usually the rears are drum and they stopped self adjusting.
