2000 F150 Wheel Bearing Assembly - 14mm, no abs
Old Apr 7, 2016 | 12:58 PM
SaveMy150's Avatar
Looking for front wheel bearing and hub assembly for a buddy’s vehicle (2000 Ford F-150 4WD XL 4.2L – 6Cyl) which has 5 studs and is 14mm, but without front ABS (no wires to hub). Any reason I can’t find a Motorcraft part #?
The closest I found was a Timken 515028 (listed 5-Stud-M14 2-Wheel ABS )? But he wanted Motorcraft if possible.
Any similar experience out there?
Old Apr 7, 2016 | 03:18 PM
AndersonS's Avatar
XL3Z1104BC
http://www.rockauto.com/en/catalog/f...+assembly,1636
Old Apr 7, 2016 | 04:26 PM
SaveMy150's Avatar
Thanks, but I unfortunately should have added that I did order a pair of these from RockAuto, and now have to return them (Or if I have enough cash, save them for my 98 F150 that has 12 mm studs). But before I distract myself, looking for motorcraft 5 lug 14mm assembly, w/o abs...
Old Apr 7, 2016 | 07:12 PM
SaveMy150's Avatar
OK, Ford Parts said Motorcraft HUB-104 is discontinued! Found a couple of vintage suppliers, but pretty $$. So I'm probably gonna go with the Timken 515028 (listed to fit 2000 F150 4WD 2-Wheel ABS 5-Stud M14).
Old Apr 7, 2016 | 08:52 PM
Roadie's Avatar
The motorcraft front bearing hub I bought from rockauto came with Timken bearings.
