Seat/center console question
Old Mar 7, 2016 | 03:47 PM
maxh64's Avatar
Alright, so I have a 2002 Ext. cab with the front bench seat. I was wondering if it is possible to swap in a front bucket seat, and put in a center console? I have seen people put expy center consoles, but I would be fine with the F150's. My last 10th gen was the 2 front buckets w/ center console. My new one is front bench. But the passenger is a bucket. So can I bolt in a new front bucket seat and then bolt in a center console? Or will some custom work/fabrication be needed? Thanks
Old Mar 7, 2016 | 05:33 PM
Should be bolt in.
Look under seat. If your seat bolts under just the passenger seat 40% you can cut your existing frame and reuse almost everything you have.
If it bolts to the floor in the full 60% you'd need new tracks and lower seat pan
Old Mar 7, 2016 | 07:56 PM
kd4gij's Avatar
If you have a solid bench or any other for that matter you can switch to buckets and a center console All the holes are there but not taped. If you have an impact the bolts are self taping. They are m12 I believe.
