Help! Can't remove driver side window actuator rod clip!
Old Jan 13, 2016 | 08:39 PM
Randori's Avatar
I'm replacing the driver's side door lock cylinder (thanks to some n'er-do-well) on my 2002 F-150 XLT. One of the 10mm nuts that holds on the exterior door handle assembly is perched directly behind the window actuator rod. There's a type of yellow clip here, similar to those I found on my rear jump door, but I can not for the life of me get that sucker loose! Anyone been down this road before?
