97 f150 xlt 4.6 no 4wd
Old Dec 31, 2015 | 07:44 PM
kaslesen's Avatar
I dont know if this is in the right place or not. sorry... I have replaced the transfer case position switch(it was bad) as well as the gem(thought i had troubleshot it down to this) and still I am not able to get the correct signal sent to the vacuum solenoids to engage the front diff, also no dash light when shifting. This is MSOF. I have the new style solenoids coming in and intend on replacing them as they are a failure waiting to happen. I am lost as to what to do next....Help please
Old Dec 31, 2015 | 07:56 PM
Have you checked Fuse #23? According to the manual it is for: 4WD clutch relay, electronic flasher, 4WD/2WD vacuum solenoids and trailer tow battery charge relay.
Old Dec 31, 2015 | 09:36 PM
kaslesen's Avatar
all fuses checked with volt meter. I wish it was that simple. thanks for the response though. better than i got on another forum.
Old Dec 31, 2015 | 09:53 PM
Did you probe the test points on top of the fuses while installed for voltage or did you pull them and ohm them out?
Old Dec 31, 2015 | 10:47 PM
kaslesen's Avatar
i checked the resistance on the top points on every fuse in both the engine and the cab. I did this while installed as well as pulling the fuses associated with 4wd to check for scorch marks or breaks in the fuses regardless of continuity.
Old Dec 31, 2015 | 11:33 PM
You need to probe the top points for voltage, to rule out a problem with the contacts in the fuse box itself or a wiring issue.
Old Jan 1, 2016 | 12:17 PM
kaslesen's Avatar
fuse 23 is good. but i did find 2 other fuses that are not registering voltage??? do i start by just replacing these or are they controlled by something else like the fuses associated with the lights. they are 20 and 21.
