1997 wont turn over
ok so here it is.. ive got a 97 2wd with a 4.6. about a day before the truck wouldn't start the cruise control quit working. then i shut it off and it would not start. had it towed, and he said it was the starter. sure enough starter was bad replaced the starter and the motor will not crank over. i cleaned the grounds and reconnected all the wires. tried jumping the solenoid on the firewal. still wouldn't go. i thought maybe it needed a little jump... still nothing but now i get the rapid clicking of a pooped out battery. im at a loss of what to do any help or suggestions would be greatly appreciate! !!
Pull the battery, take it to the parts store, get it charged and tested. While the battery is out, remove and clean all connections.
new battery in it now still won't turn over. it sounds like it wants to but just won't go
i have read about maybe the a/c compressor being locked up. i can turn my crankshaft counter clockwise but not clockwise im going to remove plugs tonight and see if that will allow me to turn it. i didnt have a check engine light or anythin. . im at a loss of what to try or what it could be. i am in deserate need of a solution!
If you think its the compressor (or any other driven component/pulley), just pop the belt off for a test. Lot easier than pulling the plugs.
which way should it spin? ive read both direction. . like i said i can spin it counter clockwise but not clockwise.
Originally Posted by metalhappy
(Post 5156878)
the motor does NOT turn over you can hear the starter kick in and it sounds like it turns maybe an eighth of an inch but just wont go.. in other words it wants to but wont... guess you could say its constipated lol
If you can turn the motor by hand then I would think maybe the starter you put in isn't doing the job. It wouldn't be the first time that a re-man part was bad out of the box.
You didn't het it real hot or run it low on oil, did you? Could also be a bad cable too. |
did not get hot nor low on oil. maybe bad cable though or like you said maybe bad starter. if it would ever stop raining id go out and see
ok soooo. took the belt off and everything turns except the a/c compressor. can i just get a.smaller belt or do i need to replace the compressor?
