2001 rough idle and evap
Old Jun 20, 2015 | 03:49 PM
scottw8's Avatar
I have a 2001 F-150 5.4L. I have a rough idle, but around 1200 RPM's it feels a pretty smooth. I pulled the codes and I am getting a P0171, P0174, P0457. I know that P0457 is for the fuel cap, but I believe that it is not the fuel cap but one of the solenoid valves for the EVAP system causing this problem.
Can the P0457 issue cause a rough idle?
Are P0171 and P0174 related to the P0457 issue?
I should also mention that I just replaced 2 coil packs. Could they have caused the P0171 and P0174 codes?
Old Jun 20, 2015 | 07:06 PM
You probably have a vacuum leak. Check the PCV elbow behind the intake.
Old Jun 20, 2015 | 07:08 PM
jgger's Avatar
171 &174 are lean codes, most common cause on the 5.4 is the PCV elbow at the back of the intake.
However if you have a solenoid stuck open so the motor is sucking extra air then that MIGHT cause the lean condition.
Old Jun 20, 2015 | 09:48 PM
scottw8's Avatar
I will check the PCV hose tomorrow. Thanks I will let y'all know what I find.
Old Jun 23, 2015 | 08:57 PM
scottw8's Avatar
Okay, on Sunday I pulled the PCV hose apart. I cleaned and inspected it, including the elbow. Everything looks good there. I cleared the codes using my scanner since I just replaced those coil packs I wanted start fresh. Today the check engine light came back on. The only codes that are showing now is p0455 and p0457. So I guess my next step is to go through this EVAP system.
Old Jun 23, 2015 | 09:14 PM
projectSHO89's Avatar
Start with a new Motorcraft (ONLY!) gas cap.
