New Truck - Intake Manifold and Other Maint
Old May 27, 2015 | 08:21 PM
personmans's Avatar
Post New Truck - Intake Manifold and Other Maint
Hey everyone,
I'm new to the forums and proud new owner of this:
A couple weeks ago I bought an '03 F150 with 130k on it and didn't know it at the time, but the intake manifold was cracked on the passenger side where the coolant crossover connects. There was no visible crack, but the leak was obvious when I saw a pool of coolant sitting on top of the block. Once removed, I flipped the intake manifold over and the crack was obvious.
Intake Manifold:
I spent 10 hours on Friday (5/22) swapping it out for a new Dorman manifold and did laser iridium plugs at the same time. I also cleaned everything in sight, looked like the previous owner only opened the hood to check fluids. Note: If you do this swap, make SURE you put the O-Ring on the elbow connector. The instructions don't mention an O-Ring, nor do they mention putting one on during installation.
Other Maint:
The next few things planned are:
Clean Interior - It's a fleet vehicle, so it's got rubber mats and hard plastic floors like a police car, easy to clean but looks like it's never been done.
Headlight Restore - The headlights are in horrible shape, very yellowed and oxidized.
Interior LED Swap - The more practical part of this is the map lights/festoons, the 'fun' part is a brighter gauge cluster.
Brake Light LED Swap - This is important for me because my current LED illuminates my tool boxes and lights up my mirror, the effect means I can't see anything in my rear-view while braking.
I'm looking for practical, easy, and cheap. If there is anything I'm missing here, please let me know.
Old May 28, 2015 | 12:51 AM
AndersonS's Avatar
Nice. I just did my intake manifold. Dorman unit felt a little cheap.
Old May 28, 2015 | 10:16 AM
personmans's Avatar
Don't know that I entirely agree with that. The lack of threaded inserts felt very cheap, but the plastic itself is heftier than the original Ford part. The gasket design and elbow design make it better than the original part IMO.
Did the Dome and Map lights last night. Here are some befores of the dome light (Looking in from passenger window, in from interior, then at dash from interior):
And After (just dome):
This is with the dome and both maps on:
Old May 29, 2015 | 12:11 PM
personmans's Avatar
Thumbs down Post Moderation
Apparently my last post is awaiting moderation.
Short version: I did interior lights and I don't think the Dorman is entirely bad.
The Dorman definitely has a better gasket design and is a thicker plastic. The lack of threaded inserts was annoying, I definitely would have paid another $10 to have the brass inserts.
Old May 29, 2015 | 04:51 PM
jethat's Avatar
I've used a doorman intake with no issues. Allot of the bolts that in the OEM intake has metal sleeves are self tapping screw that go straight into the plastic. Thats the only"cheap" issue. They work just fine and some thing about it do seem better.
