2001 with LSD and the shudder when turning
Old Mar 26, 2015 | 09:49 AM
Raybz's Avatar
Hi folks
If this is in the wrong section I'm sorry
I have a 2001 F150 Crew 5.7L 4X4 with LSD. Just bought it
After driving a while it gets the classic rear end chatter when turning. When cold no chatter. I know 1st step is to drain the pumpkin and refill adding friction modifier. Now I'm a former Jeep Jockey and beck in those days after a day wheeling and doing a lot of water crossings it was common to do up a drain and fill of both diffs. We would typically clean the gears with brake clean then fill. These were mostly open diffs and the rare lunchbox locker. Is there a problem with cleaning the 9.75LSD with brake clean? Thanks for any relpies
-Raybz
Old Mar 26, 2015 | 12:15 PM
VR6Madnes's Avatar
5.4? My truck is doing the same thing right now so I will be following this one. Just changed the diff fluid last summer with royal purple
Old Mar 26, 2015 | 12:39 PM
Raybz's Avatar
Yeah a 5.4, I don't have my glasses on today
Did you clean everything or just do a juice swap?
Did you add Friction modifier?
Old Mar 26, 2015 | 02:17 PM
VR6Madnes's Avatar
Yea i cleaned it pretty good. The royal purple is suppose to have the additive in it but maybe i should consider adding some extra. Mines not real bad, just when i take sharp turns on pavement it will shudder a bit.
