'02 F150 4x4 won't steer!
Old Jan 19, 2015 | 11:15 PM
98 f150 4x's Avatar
I recently purchased an '02 F150 4x4 that won't steer. The steering wheel turns about 2.5 turns in each direction, but the only time the front wheels move is at full lock to the left they'll turn 1/2" or so. I'v checked the obvious, like verifying the pitman arm is atatched to the box, and the steering shaft turns where it conects to the box(sector shaft?) too. Are there any other possibilities besides the steering box being toast?
Old Jan 20, 2015 | 12:47 AM
Does the pitman arm move and move the linkage? If it doesn't when you turn the wheel and the shaft turns, the box is toast.
Old Jan 20, 2015 | 08:47 AM
98 f150 4x's Avatar
Nope, pitman arm doesn't move.
Old Jan 20, 2015 | 08:52 AM
98 f150 4x's Avatar
Oh, and I forgot to mention the shaft that the pitman arm fastens to has droped out of the box about an inch. Is it possible I could just take it apart and replace a shear pin or something simple?
Old Jan 20, 2015 | 01:58 PM
grizzstang's Avatar
It sounds like your steering box is indeed toast. I would not attempt fixing it, just go buy a rebuilt one and save yourself some headaches.
Old Jan 20, 2015 | 02:26 PM
An aftermarket reman box is only around 100 bucks plus core charge.
Old Jan 20, 2015 | 03:19 PM
98 f150 4x's Avatar
Thanks guys. I guess I'll get started taking it off....
Old Jan 20, 2015 | 07:34 PM
It also would be as good a time as any to flush the power steering fluid, replace it with synthetic Mercon V spec ATF.
Old Jan 21, 2015 | 08:50 AM
98 f150 4x's Avatar
Good idea, the stuff that's coming out looks like half ATF and half mud.
Old Jan 22, 2015 | 04:13 PM
98 f150 4x's Avatar
Well, I got the old box off and a rebuilt one's on it's way!
Old Jan 29, 2015 | 05:05 PM
98 f150 4x's Avatar
Finally got the box replaced, and the truck steers now!
Old Jan 29, 2015 | 09:39 PM
Roadie's Avatar
I love it when a plan comes together! Congratulations!
Old Jan 29, 2015 | 11:22 PM
98 f150 4x's Avatar
Thanks, do I detect a hint of sarcasm in there? lol
BTW, what color is your truck?
Old Jan 30, 2015 | 12:25 PM
Roadie's Avatar
No! No! No sarcasm intended. It's always a happy moment when a problem is repaired.
My truck is blue with the tan bottom. I'm still loving it with 132k miles on it.
Old Jan 30, 2015 | 03:02 PM
98 f150 4x's Avatar
Yes it sure is! Cool, mine is a 2002 F150 Lariat FX4 Supercab 5.4L, white with grey bottom, with 175k miles.
