New Ignition Cylinder. Truck wonts starts.
Old Jun 6, 2014 | 11:31 PM
rbrown54321's Avatar
Ive seen various answers but im lost. Took the kids dirtbike riding got home and lost the keys. 2 WEEKS no keys so i drilled the ignition cylinder out bought a new one. How do i reprogram the keys.. I keep reading about the on for 15 mins then off for 3 times but i dont see the flashing PATS secuirty light blinking that i read about.. already spent 70 on the ignition and im broke. Is there a way to reprogram my new keys? Please help.. thanks
Old Jun 6, 2014 | 11:33 PM
Opps sorry.. Its a
2000 f150 4.6 4x4 of that is needed.
Old Jun 7, 2014 | 08:07 AM
projectSHO89's Avatar
You will need to have either a dealer or a locksmith reprogram the PATS system to the new keys.
There is no alternative.
Old Jun 7, 2014 | 10:49 AM
ishootstuff's Avatar
Well there are alternatives, but they aren't practical. Do a 5.4 or 6.8 swap and use a SD PCM which does not have PATS. Get a cluster, GEM, keys, and lock cylinders from another truck. Send your existing PCM to a tuner who can remove PATS.
Sorry, projectSHO89 is right. You're going to need to tow to a locksmith, or get a GOOD mobile locksmith to the truck.
Old Jun 7, 2014 | 02:19 PM
Ok thanks for the answers.. Ford did tell me i had to tow it in for them to erace the PCM ignition lock code and it would be around $50. One more question. Is there a reasonably priced PCM scanner I can buy that i can erace it myself? If so any suggestion on which one.. Thanks again for the replys!
Old Jun 7, 2014 | 08:55 PM
No. Any scan tool capable of that function will be unreasonably priced.
