1999 F150 4x4
Old May 4, 2014 | 12:04 PM
4xHIBOY's Avatar
1999 F150 4x4
Drove my truck to town to run some errands. Ran great. Got home and parked it. Went out yesterday and outa the blue it won't srart. Fuel gauge says 1/4 tank. Rolls over fine but nothin. Has the 5.4 Triton.
Old May 4, 2014 | 12:12 PM
kingkawie's Avatar
fuel pump most likely the problem. the 5.4 is known for that.
Old May 4, 2014 | 02:57 PM
When you turn the key on, do you hear the fuel pump run for a second or two? Is there any fuel pressure at the fuel rail? There's a Schrader valve on it to test, it needs 28 psi to start.
If the pump doesn't run, check the inertia switch, relays, and fuses.
Old May 7, 2014 | 06:07 AM
4xHIBOY's Avatar
Thanks for the input but I think I figured it out. Lost the original key so was using a spare. Need to get new keys because they're chipped. =glc;5083532]When you turn the key on, do you hear the fuel pump run for a second or two? Is there any fuel pressure at the fuel rail? There's a Schrader valve on it to test, it needs 28 psi to start.
If the pump doesn't run, check the inertia switch, relays, and fuses.[/QUOTE]
Old May 8, 2014 | 11:48 AM
ishootstuff's Avatar
Was the theft light blinking like crazy?
