How does our front 4x4 work?
Old Mar 30, 2014 | 09:09 AM
JMC's Avatar
JMC
25 Year Member
What Bluegrass said is true. A lot of wiring issues will be coming up that you will need to overcome. There are 104 pins on the PCM that need to be wired to the proper components. Simplest way to go about it is to pull the harnesses from your truck and replace them with the Navi harnesses. Use the complete Navi dash with the GEM that come with it and the Navi PCM. Short of that you will have to get the complete wire schematics for both vehicles and go over each and every one of the circuits to make sure they are compatible with each other. And if they are not you will have to re-pin connectors and maybe add circuits or cut and splice.
Old Mar 31, 2014 | 12:51 AM
cparbuckle's Avatar
Much better my apologies
Originally Posted by Bluegrass
I wish you well on this but my reply #4 is coming around now that your beginning to see all the issues and questions for which I was criticized for bringing up under the term 'hassle'.
Back yard engineering takes a lot of research and understanding and even then it may not all work out.
You have to look up the differences between transmission control, harness etc.
The Gem may be different. It has nothing directly to do with the PCM in an F150.
What about 4L? That's another issue that takes special handling by the GEM .
And the GEM does control a lot of other things. Is there going to be compatibility on that as well if changed out?
You have to know both systems to have any chance of knowing what can crossover and work.
It took dozens of engineers to work out the systems and your only one person going to try and cross breed two versions yet?
Good luck. I wish you the very best.
BLUEGRASS, That was Worded so much better. I retract my previous statement from your direction but it still stands for all the others who only criticize, and to the man working on this project just know that these engineers dont know everything and they are only human, it may take longer then you may want it to but im sure you will be able to figure it out in the long run Good luck and all the way around
Old Mar 31, 2014 | 08:54 AM
1998f150xlt's Avatar
Actually your original post was in reference to an axle swap, not a 4x4 to AWD swap, which is completely different. All I have to do is use my F-150 transfer case with the axle swap and it would have absolutely nothing to do with the 4x4 working or not. All I'd have to do is swap the lever into the front diff like the F150's have so it's not constantly locked.
The fact that I'm swapping in a Navigator engine is what's possibly causing a problem for my 4x4 and no it's really still not all that scary of a swap. Figure out pin outs, figure out what pieces are needed and make it work. It's really not such a big deal. There are guys who have swapped their lightnings to AWD so I know this can be done; it's just a matter of how.
There are plenty of people who have done Navigator engine swaps too, I'm not the only one trying this swap either. Ever heard of a Lincoln Blackwood? It's basically an F-150. So the Ford engineers did make all this work (not the 4x4 in the Blackwoods case obviously), you just have to not be a baby about it and not be scared to get your hands dirty to figure it all out. Too many people think everything is so difficult and abandon all cool projects because they're scared to do the legwork.
Old Mar 31, 2014 | 08:57 AM
I was going to use the Navi engine and trans harness and plug those 3 massive connectors into my firewall (after figuring out the pinouts of course). If I had to go as far as using the Navigator dash harness and GEM too I could. All I would have to change is the harness to the rear of the truck to get the tailights and such working properly.
EDIT: Heck, worst came to worst I could just wire up a manual 4x4 cable to pull the front axle into lock, and a switch to kick over the transfer case motor.
Old Mar 31, 2014 | 09:03 AM
Contender's Avatar
I like your attitude.
Make sure you start a build thread when you begin working on the truck. I think a lot of people would be interested.
Old Mar 31, 2014 | 09:09 AM
Thanks. I appreciate all the support guys. Since the Navigator is ripped apart and my engine is off at the machine shop, I guess I should start one of those now huh? Stand by.
Old Mar 31, 2014 | 10:27 AM
Ask and you shall receive.
Swap thread:
https://www.f150online.com/forums/19...ml#post5075064
