what does this look like to you guys? Intake gasket?
Old Feb 12, 2014 | 04:32 PM
jump n's Avatar
So I had been noticing a scent of antifreeze off and on lately. Checked it out today and found this.
99 F150, 5.4 with 190K miles. This is new coolant since I had my lower radiator hose burst on me back on New Years Eve. Coolant level is just below the low marking on the degas bottle.
What do you fellows think is leaking? Thermostat housing? Intake gasket? Head gasket?
Old Feb 12, 2014 | 06:29 PM
Apittslife's Avatar
from the pics I am going to say thermostat housing, or leak at the hose end.
Old Feb 12, 2014 | 06:58 PM
Halverso_99's Avatar
Maybe a leak at the elbow or t stat?
Old Feb 12, 2014 | 10:46 PM
Shine a light down into the valley - if there's puddled coolant under there it might be the O-ring on the pipe at the back of the water pump.
Old Feb 13, 2014 | 12:03 PM
str8t six's Avatar
is it leaking at the top of the t stat housing or is it below by the intake gasket?
either way, its not too hard to change.
Old Feb 13, 2014 | 12:24 PM
5.4 has plastic intake right? It could be the manifold itself. All though theres something in my head that maybe the 99 had an aluminum intake.
Old Feb 13, 2014 | 02:36 PM
jump n's Avatar
Yep, i have an aluminum intake. I'm researching this now to see what gaskets I need to replace.
Old Feb 13, 2014 | 02:38 PM
ishootstuff's Avatar
Yeah, 1999 is aluminum still.
Old Feb 13, 2014 | 02:52 PM
jbrew's Avatar
Hard to tell from the pic. He didn't take a pic of were it's leaking lol. Anyway, it's leaking at the stat housing. It's not gasketed itself, - uses the stat gasket instead.
What fails is either the housing itself, or of course the stat gasket. The housings pit and at times open up a hole in the casting itself. Those housings are cheap to replace, - so's the stat.
Old Feb 13, 2014 | 08:03 PM
jump n's Avatar
I will take a better picture soon when my weather improves and the engine isn't running.
