Best lift kit options for 03 2WD 5.4L XLT?
Old Feb 3, 2014 | 08:19 AM
kyndacrazy's Avatar
Any suggestions? I don't want a crazy high lift - maybe 2in in the back at most, and want it to be level. Also, I still plan on towing in the future. I am currently on 265/70R17 Nitto Terra Grapplers.
Old Feb 3, 2014 | 02:15 PM
thelariat02's Avatar
For the rear do an AAL. I actually have one sitting around from procomp that is suppose to add 2" that I'm never going to use
Old Feb 3, 2014 | 02:48 PM
pizzaman711's Avatar
If you only want the rear about 2" higher and you still want it to be level your options are either do a 2-3" body lift and and go with a 1.5-2" spacer or lift coil up front to level it out, go with a set of lift spindles and around a 1.5" block or aal in the rear, or a 3" coil spring or spacer with aftermarket control arms up front and around a 1-1.5" block/aal in the rear.
Old Feb 3, 2014 | 09:47 PM
kyndacrazy's Avatar
How much do you want for it?
Old Feb 3, 2014 | 09:53 PM
PM sent
