Rough Idle, AIC?
730 rpms @ warm idle is perfect. Between 700- 750 is considered normal.
For it to idle that low there's probably an obstruction. Could be as simple as a dirty air filter and MAF.
A vacuum leak would cause a high idle.
Also, being that it's idling the way it is, -the EGR valve is suspect. That could be because of a bad EVR or a partially stuck EGR valve. To cause that low of an idle, it would have to be one or other.
I take that back, it could easily be the converters. They could partially plug and cause those problems. I suppose you could have a bad PCM, but I've never heard of one causing your symptoms.
Vacuum leak is was causing my strange idle at 650 rpm. It was not giving a code. but after looking at every hose under the hood I was find the leak. after i spliced the hose back to where it connected it was a instant fix.
Never heard of that, - doesn't make sense. Which line was it? What color?
