Passenger side light doesn't work
Old Oct 13, 2013 | 04:15 PM
D's984x4's Avatar
Like the title says, my passenger side light wont work. Brights work but not the regular light. I checked the connections and everything looked fine. When I test the wires I have one that doesn't work so I am assuming thats the problem.
Anyone have any idea on where to start? Is there a fuse or relay that I should check?
D
Old Oct 13, 2013 | 04:35 PM
D's984x4's Avatar
Sorry, 1998 f150 4x4 4.6L
Old Nov 2, 2013 | 06:43 PM
D's984x4's Avatar
Anyone? I have tried all the fuses... I still haven't looked at the MFS. It seems this is only the problem for a few people.
Got pulled over and given a warning the other day and want to the this fixed!!
D
Old Nov 2, 2013 | 08:20 PM
jgger's Avatar
Start with the light bulb. There are two different elements in there, one for regular light and one for high beams.
Old Nov 2, 2013 | 10:21 PM
blupupher's Avatar
Swap bulbs and see if it still does it, at least that will rule out a bulb issue.
Old Nov 4, 2013 | 09:35 AM
D's984x4's Avatar
Bulbs are brand new and I have switched them, both work.
Old Nov 4, 2013 | 02:02 PM
dogman72's Avatar
On the 98 F150, the left low beam headlamp is circuit 160 which is the dark blue with the white stripe. In the junction box/fuse panel, book says it is number 6 and #7 is for headlamp dimmer switch to low beams. This is out of the ford repair manual for electrical for the 98.
Old Nov 9, 2013 | 02:54 PM
dogman72's Avatar
Did you ever resolve this issue? If so, what was it?
Old Nov 12, 2013 | 01:01 PM
D's984x4's Avatar
I haven't had anytime to attmept to diagnose the problem. I might just end up taking it to the dealer and just paying for it....
I have a repair book for it but right now Im more just lost with the whole problem.
Old Nov 12, 2013 | 01:25 PM
D's984x4's Avatar
Also, I have read just about all the threads and resopnses on this topic and it seems like there are 10-15 different reasons that this happens. Very inconvenient
