RCD install?
Old Aug 15, 2013 | 11:16 AM
pizzaman711's Avatar
Not past what the truck is physically rated for.
Old Aug 19, 2013 | 08:07 PM
black4v's Avatar
Ordered 4.56's.
Old Aug 19, 2013 | 08:12 PM
str8t six's Avatar
nice! what brand did you get?
Old Aug 20, 2013 | 04:50 AM
black4v's Avatar
I got the USA Standard. I've heard good stuff about it. I don't think ill be doing anything that will break it. $375 plus $78 for shipping to Guam. I have a buddy who will install both for $400. Not a bad deal. She's a road truck so i'll rarely see any off road.
Old Aug 30, 2013 | 06:03 AM
black4v's Avatar
Str8t Six, gonna start the lift soon. I would really appreciate the pics. I'm reading the part about installing the compression struts. I'm not sure where the drill the 1/2" hole on the transmission crossmember. The pic doesn't show a 1/2" bolt used. Also, I'm confused about the torsion crossmember bracket. It says to turn the crossmember over (inside the bracket) before mounting. Thanks for the help.
Old Aug 30, 2013 | 02:07 PM
str8t six's Avatar
ok, ill try and get you some pics later today.
Old Aug 31, 2013 | 01:02 AM
hockeyfanjeff's Avatar
Originally Posted by hunterjh
if you have tools ....do it yourself...good learning experience... i did my suspension lift with a floor jack and hand tools.... its just as simple as reading the instructions....i wouldnt even need em now...take off old put on new...save your 750 and do it yourself
x2
I did my RCD myself this way
Old Sep 6, 2013 | 06:10 AM
black4v's Avatar
So I finished the install but its late so I didn't adjust the adjust the ride height yet. I started out with 22 1/2 inches from center of the hub to the fenderwell. I got exactly 4 inches of lift on the passenger and 4 1/2 on the driver. I will adjust the torsion key to reduce the 1/2 inch. The problem is the rear leaf springs. The passenger is 1 inch higher than the other side. Will the leafs need time to break in and settle? Thank you for any help.
Old Sep 8, 2013 | 02:32 PM
five0merc's Avatar
Did you get new leafs?? If so yes.
You running stock wheels? Or do you have aftermarket wheels? I am getting ready to put the same lift on and like the stock wheels and prefer to keep them for a little while. Unless I absolutely need to get new wheels.
Old Sep 8, 2013 | 03:02 PM
black4v's Avatar
The kit did come with new leafs. I gonna use the stock FX4 rims and put on 315/70/17 Goodyear Duratrac's. I just finished installing the lift.
Old Sep 8, 2013 | 03:25 PM
five0merc's Avatar
Yea the leafs will settle a little bit.
Awesome post some pics of it. Those are some nice tires. I have a set of 37's for mine.
Old Sep 8, 2013 | 07:02 PM
black4v's Avatar
I'm having it aligned tomorrow and then getting the tires. I'll post pics after that.
Old Sep 9, 2013 | 10:23 PM
black4v's Avatar
Update: 35's or 315's will fit on the stock rim but it will rub the new knuckle on the RCD lift. So it's either I buy a 2" wheel adaptor or buy new rims. Not sure what to do.
Old Sep 10, 2013 | 02:53 AM
That's what I thought when you said you were using the stock wheels. Not to spend your money for you, but nice 17's can be had for $600-800, which I think is pretty good.
Old Sep 10, 2013 | 06:35 AM
black4v's Avatar
New rims are whats gonna happen now. I was basing myself on the guys who do a 3"BL. They run the stock rim and the stock knuckle angle will allow for 35's. Anyway, a good set of 35's run about 1700 bucks here on Guam and not much less for 33's. Rims and tires will be about 2300 to 2500. Seems like a safer choice that using 2" wheel adaptors. Oh well, we only live once.
