My 97 2wd f150 stepside 4.6L XLT
Old Jun 21, 2013 | 10:09 AM
fr86712's Avatar
I just recently brought a 3 inch body lift kit ( 3'' coil spring spacer; 3'' rear blocks) after installing these components, is it possible to fit 375/75/16's without rubbing?
If not what would be the maximum tire size i can use with no rubbing?
Old Jun 21, 2013 | 12:55 PM
pizzaman711's Avatar
Hopefully you bought after market control arms too or you'll never get it aligned and have terrible ball joint angles.
And there is no way your clearing a 38x14.50 on 6" of lift on a 2wd. Better go up to about 12" if you wanna clear those.
Those most you'll clear is a 315/75r16 or a 35x12.50 with some rubbing and some trimming dependent on the wheel.
Without rubbing maybe like a 295/75r16 or a 305/75r16. Which are in the 33-34x12ish range.
