HVAC vacuum lines
Old Jun 11, 2013 | 06:15 PM
fordf150farmer's Avatar
HVAC vacuum lines
My HVAC is defaulting to defrost under acceleration. It makes no difference if it is on heat or A/C. I did a search and it seems the issue is most likely a vacuum leak. So I'm wondering is there a common place where leaks occur or a line that is prone to going bad?
Thanks for any input. Oh and its a 97 4.6 xlt
Old Jun 11, 2013 | 06:57 PM
Yes, check the little plastic hard lines behind the battery.
Old Jun 11, 2013 | 08:40 PM
Thanks i will give that a try, I was under the impression the only ones back there were for the 4x4. Learn something new everyday. Ill check it out and see what i can find
Old Jun 11, 2013 | 09:57 PM
Well, after a little poking, this is what i found,
The line deteriorated, probably from acid from the last battery. After i pulled the end out of the rubber connector i put a dab of super glue on the male end of the left over tube (so it would stay in since the barbed piece is now gone) and after a test drive no more cutting out heat or air!
Thanks a lot!
