5.4 lightning swap
Old May 31, 2013 | 09:52 AM
jbrew's Avatar
Originally Posted by JMC
Manual t-case and a Posi-lok cable for the front diff...
Right, what runs the actuator ? I suppose that's what the cable is for. Yea, that's a good idea.
Old May 31, 2013 | 09:54 AM
jbrew's Avatar
Originally Posted by Usmcjwg
I'm not using the truck for a race vehicle just towing and everyday driving. I would rather die than lose 4 wd and I think I have the 4r100 tranny already. I need to know will this swap be as simple as taking my entire engine out and bolting this entire engine in. I can get the fuel pump as well and the fuel rail,injectors and such will all still be on the new engine. I can get this engine cheaper than a remain factory 5.4 and that's what I'm looking for. The fact that it has the supercharger is a bonus but only if its not going to cost me a furtune in other things ie exhaust etc.
Just look inside the drivers door under trans code.
Old May 31, 2013 | 10:37 AM
str8t six's Avatar
im pretty damn positive you dont have a 4r100 trans. since those are mostly on expi's and f250LD's
Old May 31, 2013 | 11:37 AM
jbrew's Avatar
Mine has one. Well, it has E4OD on the door jam, but once you pull the pan, 4R100 is painted everywhere. Frankenstein at the factory, mine was probably built from the left over parts. Maybe the parts that were booboo'ed on the line?
Old May 31, 2013 | 01:30 PM
jbrew's Avatar
Originally Posted by jbrew View Post
Troll Alert^^^^
That for that Image that guy posted, - if you click it, you go right to Amazon . com.
Old May 31, 2013 | 01:32 PM
jbrew's Avatar
I'm not losing my 4x4 and my truck
Has 307000 miles and the engine is tired I'm going to use it for towing I have a lift and big tires so not looking to go fast and I think my truck has the 100 tranny already. I can get this engine with what I need cheaper than a replacement engine it is complete with injectors and I can even get the fuel pump. I just don't want to do it if its going to cost me a furtune in exhaust an such. But if everything I have now will just bolt up with the new engine then I will do it
Where's that Lightning at?
Old May 31, 2013 | 02:53 PM
Usmcjwg's Avatar
South Carolina
Old May 31, 2013 | 03:00 PM
Usmcjwg's Avatar
The local ford dealership said the only difference I would run into would be the fuel pump and the PCM does that sound right because I can have my PCM programmed and I have the fuel pump
Old May 31, 2013 | 03:01 PM
Usmcjwg's Avatar
They even said my exhaust would fit but may have to swap oil pans
Old May 31, 2013 | 03:48 PM
jbrew's Avatar
Well, I guess your all set then, - don't listen to us..
Old May 31, 2013 | 04:26 PM
str8t six's Avatar
yes, i know some of the earlier 97-98 f150's had the 4r100, but he has a 01 screw which never came with the 4r100's. thats what i was saying.
USMC, your going to have to change some suspension mounts and driveshafts if youre changing to the 4r100 trans.
why would you need to change oil pans? im pretty sure they are the same.
Old May 31, 2013 | 06:10 PM
Veteran: Army
sounds like the dealership saw the sign on this dudes forehead, forget our expereince
Old May 31, 2013 | 06:32 PM
Toyz's Avatar
Who goes to the dealer to ask questions regarding swapping engines...?
Old May 31, 2013 | 06:43 PM
Usmcjwg's Avatar
Listen smart asses I went to the dealership to ask because you all was telling me to swap this an that and never told me a straight up answer on if it would or not so I didn't know what else to do. If you all would give a straight answer then I would have new from you all.
Old May 31, 2013 | 06:44 PM
Usmcjwg's Avatar
Last thread not intended for the ones who actually helped me just for the know it alls on here
