Fully boxed frame
Old May 25, 2013 | 04:16 PM
Wolvee's Avatar
Originally Posted by AndersonS
You just want to pull weight?
Buy a Tundra. It can tow a space shuttle.
It can also pull the piston through the oil pan.
Old May 25, 2013 | 10:05 PM
AndersonS's Avatar
Originally Posted by ccdline73
If I had a gooseneck then towing would matter. You guys are just crushing my hopes and dreams! haha
Nothing wrong with improving your truck's performance, just be smart about it. I'm pretty sure your axle, springs, brakes, and transmission are most at risk if you're gonna exceed ratings. Chassis failure is further down the abuse line.
Patman's suggestion is pretty awesome.
As much as we crap on the Tundras, the 5.7 is a sweet engine... especially in a regular cab short bed.
Old May 25, 2013 | 10:12 PM
Wolvee's Avatar
The new Tundra engine are better but the first ones blew more than a few connecting rods.
Old May 25, 2013 | 10:15 PM
AndersonS's Avatar
The early ones apparently broke camshafts as well.
Old May 26, 2013 | 12:17 AM
ccdline73's Avatar
I do like patmans idea. It might sound dumb but I just wanted to know my truck was more capable and stouter even if I wasn't hauling or towing past the recommended rating. Guess im used to customizing stuff for no reason at work haha. I really want to strengthen the frame under the bed cuz it bugs me when I see that the frame is only 4 inches tall. Idk I'll keep thinking about it and see where it goes
Old May 26, 2013 | 09:42 AM
AndersonS's Avatar
You can go and box the whole chassis, but I'm sure you and your engineering buddy know that braces will save weight, labor, and material. A tubular frame would be even stronger.
Old May 26, 2013 | 11:34 AM
Veteran: Army
We were going to be getting the steel for free and as for losing performance i don't think that would be a big problem since i will be pulling the motor out next year to do a full build and turbo. Ill check out the stifflers x brace but i was just trying to make it have the strength of a 1 ton but look like a half ton, kind of a sleeper look. Just thought it would be badass
so why not do a frame swap with a 3/4 ton or larger truck?? and then use the F-150 body??
Old May 28, 2013 | 04:07 PM
Halverso_99's Avatar
I say if you wanna do it, then just go for it. And be sure to post pics along the way.
Old May 28, 2013 | 04:16 PM
Wolvee's Avatar
Do people still do that kind of thing with modern Ford Trucks?
(I'm a Car guy, so I have no idea.)
Old May 29, 2013 | 05:51 AM
Veteran: Army
you'd be suprised
Old May 29, 2013 | 07:11 AM
Stifflers X-brace....FTW.....
Old May 29, 2013 | 07:48 AM
Veteran: Army
Old May 29, 2013 | 04:36 PM
Wolvee's Avatar
Stifflers mom FTMFW.
Old May 29, 2013 | 05:26 PM
So from what I have researched the x-brace is only for 2wd?
Old May 29, 2013 | 06:10 PM
AndersonS's Avatar
That's what I figured as well. I hope that's wrong, because their complete kit with traction bars looks like something I might want. I kinda drive my truck like a car.
