Does my truck look retarded?
I got a 2" leveling kit installed and then put 33" A/T's and 20" MB Tko's on it and at first it looked great to me.. But here lately, I feel like it looks stupid. I don't know why but it's like I got too big of wheels and the tires are stuffed in the fender wells... Is there anything I can do to maybe make it look better? Or more "appealing" as some would say. I went and measure from the center of the fender in the front and back to the ground and the back is still sitting about an inch and a half higher. So I was thinking about getting a 1.5" Coil spring from rough country to lift it up and actually level it out.. Would that make it look better? Any suggestions and opinions and whatever else would be greatly appreciated.
Thanks!
Thanks!
Thank you for your input, I do appreciate it. And thank you for giving it compliments too. I usually do keep it clean but I tend to take dirt roads with friends and end up in ditches and pastures mudding, which was why I did the leveling kit and 33's.
Tinted Windows and Taillights soon to come. Lol
I think it looks pretty good. The wheels wouldn't be MY first choice, but they don't look bad. From the pictures it looks pretty level to me. You're 2" leveling kit is probably actually the 1.5" Daystar leveling spacer. Most of the shops in my area use Daystar for all of their leveling kits. I would avoid using leveling springs in conjunction with the spacer.
Are you wanting to actually lift the truck up higher? You could add 3.5" spindles for about $300. But if you want a more leveled and not lifted look this wouldn't be the best idea. Or you could run 3" springs with aftermarket control arms and ditch the leveling kit (this option would raise you up probably another 2" in the front, but would run you about $200 more).
Retarded no, stuffed yeah but several on here try to fit as much as they can get away with. Might need a little more lift for room to flex. But like the others said, I would go for tint and taking off side molding and maybe the pin stripe.
I agree with the chrome wheel comment, but I think the size of wheel and tire is perfect. The black wheels just add a little too much when you have two tone plus chrome. You have introduced a 4th color and personaly, two is all I like.
