humming noise but not when turning right
I have a 1998, F150, 230,000 miles. Humming noise in the front started three weeks ago. stops when turning right. Does that indicate the right wheel is the problem? I am guessing it is either the hubs or the bearings. Replaced bearings, rotors and pads last summer on both sides after greasing the bearings thoroughly. Did not grease the spindle when putting the new hub on. Any suggestions? Am unsure which side to start on and what the problem might look like.
help! I have a 1998, F150, 230,000 miles. Humming noise in the front started three weeks ago. stops when turning right. Does that indicate the right wheel is the problem? I am guessing it is either the hubs or the bearings. Replaced bearings, rotors and pads last summer on both sides after greasing the bearings thoroughly. Did not grease the spindle when putting the new hub on. Any suggestions? Am unsure which side to start on and what the problem might look like.
