ABS light comes on , stays on
Old Apr 22, 2013 | 11:24 PM
desertrat1959's Avatar
Wondering if anyone has had a ABS light problem like this: When I start up in the morning ,no light till I get to the first stop sign , about 100 yards. when I apply the brakes ,Voila ! light comes on . the front brakes are only a year old , the rear brakes needed changing , got those changed , still have the light come on every day. Does anyone know where the ABS modules are located ? All I can gather from my Chiltons that there are 2 ...don't know what to do from here, any suggestions ...thanks
Old Apr 23, 2013 | 01:29 AM
jgger's Avatar
Take it some place that can read ABS codes, auto part stores usually can't.
Most likely is a wheel speed sensor or the wires that go to it have rubbed or are broken. Excessive crap on the sensor might cause it to, but I doubt it.
Old Apr 23, 2013 | 08:26 PM
its typically the VSS in the rear end, but you need to get the code read before you just throw parts at it
Old Apr 24, 2013 | 04:12 PM
Thanks will do!!
Thanks will do.!!
Old Apr 26, 2013 | 01:27 PM
ryan.sampson's Avatar
Is it 4wd? If it is there a sensor in each front wheel bearing hub and one in the rear diff if I'm not mistaken. Bad brakes shouldn't affect the abs at all, most likely a junk sensor or chaffed wire
