P0171 and exhaust leak
Hello, I had an exhaust manifold stud rust away on my 97 4.6L on the passenger side. I had bought one of those clamp-a-stud things to fix it, hadn't gotten a chance. Started truck Saturday, loud as usual, also got Check Engine code P0171.. I finally installed the clamp to fix the exhaust leak, and reset the Check Engine light. Could the Bank 1 lean error be caused by the exhaust leak? I am hoping so, I am due for state inspection...
If you cleared the codes, you are going to have to drive it for a while before inspection so all sensors achieve readiness status. If you have a capable scanner, check it before you go to make sure there isn't a P1000 in there. If there is, DO NOT try to clear anything or it will just start the cycle over again.
