2002 F150 Temp 160 degree problem
Old Feb 15, 2013 | 05:10 PM
sd72667's Avatar
So my truck motor (2002 Ford F150 Lariet Supercrew) isn't coming up to temp. Only 160 degrees. I replaced the thermostat and flushed the system and new antifreeze. Even though I installed a 192 degree thermostat, it still only reaches 160. It's a 5.4 Ford. The heater core acts as the bypass and it has the resistor in the heater hose. Any ideas?
Old Feb 15, 2013 | 06:34 PM
How are you measuring the exact temperature?
Old Feb 15, 2013 | 07:24 PM
sd72667's Avatar
Infrared thermometer at the thermostat housing
Old Feb 15, 2013 | 09:08 PM
JMC's Avatar
JMC
25 Year Member
Might be low coolant. Is the degas bottle low? If not there may be air in the system.
Old Feb 15, 2013 | 10:15 PM
sd72667's Avatar
No, all that's good.
