ext. cab with crew bed on std. frame
Old Nov 20, 2012 | 12:27 AM
02FORD4X4's Avatar
not the best looking combo out there...
Old Nov 20, 2012 | 06:23 AM
chrmar's Avatar
I think the only way to build something like this would be with frame grafting. Using anything other than a supercab bed for a supercab cab would result in wacky mounts due to frame kick-up.
Old Nov 20, 2012 | 10:48 PM
rus's Avatar
rus
Originally Posted by 94fiveohvert
i like it, wonder if a standard cab long bed frame would be required... how many frames were there for these trucks?
Easy way would be to take your supercab truck and switch the back frame and bed off the supercrew setup. The frames both are riveted right behind the cab. Blow out the rivets and swap and reweld. Change the drive shaft and the rest should be a direct fit.
Old Nov 26, 2012 | 01:44 PM
61 Sunliner's Avatar
How about a Screw cab with the stepside bed, it would be long but might be cool.
Mike
Old Nov 26, 2012 | 01:50 PM
Other than the step, the 01-03 Screw bed is just a short version of the Flareside bed. Same taillights, same tailgate.
Old Nov 26, 2012 | 01:51 PM
02FORD4X4's Avatar
ive seen one before. it looked prettty good
Old Nov 26, 2012 | 07:24 PM
AndersonS's Avatar
The only reason I see to contemplate changing the wheelbase/chassis of the original truck would be to install a long travel prerunner suspension.
Old Sep 5, 2018 | 10:22 AM
Paul888's Avatar
That is a gorgeous truck.
Old Sep 11, 2018 | 01:06 PM
Fbird's Avatar
sound like OP is liking a 1/2 ton "sport trac"
like what they did with the explorer.
