What gear ratio to go with?
Old Oct 19, 2012 | 05:06 PM
ParnAZ's Avatar
Originally Posted by ONELOWF
My deal was 410s from 355s, with close to stock tire height, so a 23 tooth gear gave an OK correction where I am within 2-3 mph at 60 mph. I think that is pretty good.
Was that 2-3 above or below actual?
In almost the same boat you are going to 4.10 w/29.5" tire
Old Oct 19, 2012 | 07:43 PM
JHL's Avatar
JHL
Ditto
Old Oct 20, 2012 | 02:45 PM
ONELOWF's Avatar
Sorry, I don't recall, the gear swap was in 99'! If you are within 2-3 mph either way, above or below actual, I would say you're doing good. No? A tire size decrease or increase if .5" in diameter could be about that much......
With your 4.10 w/29.5" tire you have to go with a 23 tooth gear, as far as I know there is no other option available other than custom tuning.
Old Oct 22, 2012 | 09:24 PM
ParnAZ's Avatar
Sounds good thanks just tryin to avoid any...unwanted attention
Old May 6, 2013 | 12:26 PM
ParnAZ's Avatar
Just a bump for an old thread. FYI with stock tire size and 3.55s going to 4.10s the speedo will read 2-3 OVER actual with a 23 tooth VSS gear. Just did this swap and although the difference was not dramatic it was definitely noticeable. MPGs dropped by 1 with alot of mixed city/hwy driving.
Old May 6, 2013 | 04:33 PM
2 to 3 over is probably close to right on for the ECM. Ford sets the speedo to read a bit high on purpose. Check the odometer against highway mileposts or a GPS, it's probably very close to exact.
