Tire Wheel and Lift Question
First off thank you all again for all your help! The truck is running amazing and has been very good to me so far!
I need new tires and figure I might as well get the wheels and height out of the truck I want now instead of wasting money and doing it all over again in a year. I want a slight lift 2 inches(ish). Any advice on how to do so? I keep hearing about cranking up the stock torsion keys, will that raise the back as well or just level it? I would like to raise the back a bit as well! Also I would like to run 275 65 18's on the truck. Will those fit with a bone stock truck? Also does anyone have pictures of those size wheels/tires?
Oh the truck is a 2003 F150 XL 4.2 4x4 5 speed manual. I DO NOT want to regear, will my truck handle the slight tire increase all right or should I look for a smaller size?
Thanks a million!
Thanks a million!
-Cranking the torsion bars will only level the front. Every truck is different so don't know how much lift you'll get out of it until you actually do it.
-Odds are, this will place the front about level, so if you want to lift the rear, you'll end with that nose low rake again.
-That's about a 32" diameter tire, so you should be way fine with fitment and drivability.
-Why are you against re-gearing? That's hands down, the best performance mod I've ever done to ANY car or truck I've ever owned, including this one!
Thanks for your quick response
By drivability, I meant that going to a 32" tire isn't going to kill the power of your truck. Cranking the torsion bars may give you a slightly firmer ride in the front, but nothing of a negative nature. Truck will drive the same as it always has.
