97 (another) speedometer not working
Old Aug 8, 2012 | 12:34 PM
chasmosis1's Avatar
Hi guys, obviously I'm new here. I found the site through Google. My search on Google & searching the forum here has yielded me no results. My dad is 2000 miles away and I am trying to help him get his speedometer working. The truck is a 97 f150 3-door extended cab, 4.6, 2wd, auto. He changed both speed senders (transmission tail housing & rear axle), and I sent him a replacement cluster from a wrecking yard (unknown whether it previously worked or not). Still no speedometer, odometer, or cruise. When I was there in June I used my scanner on it and the scanner reads the speed correctly, so I know the senders are reading. The truck does give a VSS code (PO500). Any ideas?
Old Aug 8, 2012 | 03:31 PM
SubSkip's Avatar
P0500 Vehicle Speed Sensor (VSS) A
DTC P0502
Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
http://www.obd-codes.com/p0500
Old Aug 11, 2012 | 11:30 AM
chasmosis1's Avatar
Thanks for the link SubSkip. Anybody else have any ideas?
