1997 XLT 2WD shocks
First time poster!
Questions on shocks: It's been a while since I've replaced them (so long I can't remember
). Current mileage is ~140K. No "noticeable" issues, but I'm probably past the recommended replacement period and I want a small project. Just got new tires (Cooper Discoverer 265/75/16). I don't haul/tow anything noteworthy often enough to factor in.
I can get a full set of KYB GR-2 / Excel-G for $133.58 or a set of KYB MonoMax for $244.97 from RockAuto (shipped).
For regular highway/street driving, is it worth the extra 100 bucks to get the MonoMax's?
Thanks for your time and advice!
). Current mileage is ~140K. No "noticeable" issues, but I'm probably past the recommended replacement period and I want a small project. Just got new tires (Cooper Discoverer 265/75/16). I don't haul/tow anything noteworthy often enough to factor in.- How difficult are they to replace?
- Any special tools required?
:Welcome!!!!!!!!!
personally I am a Pro Comp Shocks Fan. and they are decently priced too.
Pro Comp ES3000 Hyrdo
Front: EXP315517
Rear: EXP324510
total price for all 4 is: 151.96
Pro Comp ES9000 Nirto Charged (my Favorite)
Front: EXP915517
Rear:EXP924510
and 4wp has them on sale for buy 3 get 1 free!!
As far as tools. when i do shock swaps i use a pair of vice grips and a 3/16 gear wrench.
Front: EXP315517
Rear: EXP324510
Front: EXP915517
Rear:EXP924510
Whats The torque specs on the new shocks bolts? Everyone tells me to tighten it a different way- either in pounds, how many threads are showing, how crushed the new bushing is, etc.
Whats correct?
Whats correct?
Well, according to the trusty Haynes manual (for 2WD):
Front:
Upper = 35 to 46 ft-lbs
Lower = 22 to 29 ft-lbs
Rear:
Upper = 22 to 29 ft-lbs
Lower = 44 to 60 ft-lbs
I did 70-80 ft pounds on the top lol.
Wish I never lent out my Haynes manual.
Some lessons learned:
- No instructions were included in the boxes nor were there any to view on Pro Comp's website.
- Didn't have to remove any of the tires. Just lift and set on jacks. (Stock height, no lift)
- Front shocks were pretty easy. Took about an hour to do both fronts.
- Rear was a PITA. First the inserts on the bottom of the old shocks were destroyed, so I had to hammer out the bolt. Top of driver side: took forever to be able to just start the nut on the thread. Had to put the nut on without the metal washer and let it sit for a bit to compress the rubber bushing to be able to thread the nut with the washer in place.
- Had a hard time tightening the top nuts and preventing the shock shaft from turning. (really takes two people and a set of channel locks)
- The $20 hydraulic jack from Walmart will not lift high enough to get your truck off the ground. /noob
- I'm too old for this s*!t.
I accomplished my task of doing it myself, but I think I'll spend the extra $100 to have someone else install them for me next time.
Let me know if you guys have any questions. I only road it around the block a few times for road testing. Not much to report yet.
/cheers
