Alternator
Old Jul 21, 2012 | 04:03 PM
pondman3306's Avatar
Alternator
Plugged connector in backwards into alternator, now according to AutoZone's test machine Alternator is bad. Can I just replace the regulator or would the rectifier have also been damaged? Or should I just bite the bullet and get a rebuilt one?
Old Jul 21, 2012 | 04:32 PM
jbrew's Avatar
Not sure how that would blow it. Seems to me, a surge of some kind would have blew the inline fuse connected to the 175 MAXI/Harness cradle.
Regardless, if needing a new one, I would fish ebay for an OEM Motorcraft replacement. You can find those cheap sometimes. If you look among the used Alts you often come across new take offs. They can't be sold as new, but are new just the same.
When it comes to those cheap rebuilds, even guaranteed replacements may have you traveling to and from the supplier until you happen to get one that will last a little while.
Old Jul 21, 2012 | 06:33 PM
So far, I'm having good luck with a lifetime warranty O'Reilly reman.
Old Jul 22, 2012 | 08:16 AM
Just wanted to know if changing the regulator would repair the alternator. Would the alternator still produce voltage with the regulator bad. My thoughts that it would still produce voltage just not regulated so we are looking at any where from 12 to 20 volts am I think right?
Old Jul 22, 2012 | 08:33 AM
jbrew's Avatar
Well excuse us, - but it depends what exactly happened to it. There's more to it than what you posted. Connecting it backwards didn't do it. What else did you do to it?
Old Jul 22, 2012 | 10:44 AM
jbrew's Avatar
Just search "Alternator testing procedure". Might want to search the electrical forum since that is the proper forum.
Old Jul 22, 2012 | 12:17 PM
Red02FX4's Avatar
the regulator is built in to the alternator. most people just go get another (new or reman) alternator, but if you feel comfortable taking the thing apart to try to fix it..... have at it
Old Jul 22, 2012 | 02:28 PM
What happened
Took alternator off to remove intake manifold to repair broken heater tube at rear of manifold. Replaced plugs, new o-rings on injectors and new gaskets on intake manifold. Replaced intake, reinstalled alternator, plugged in connector (backwards as I said) reconnected battery cable, started engine. Went for a drive down the street about a mile, that's when I noticed the battery light on.
Checked the connections and found that I had plugged the connector in wrong.
Put connector in the right way, turned engine back on, battery light still on.
Took alternator off and took it to auto zone where they tested it 2 times and both times it said failed. Why I am questioning all of you is that a rebuilt alternator is 170.00 dollars. If it is just a matter of getting a regulator for 40.00 dollars I save 130.00 of my hard earned money. Is that explanation enough???
Old Jul 22, 2012 | 03:06 PM
Red02FX4's Avatar
GOOD LUCK
Old Jul 22, 2012 | 03:26 PM
jbrew's Avatar
I already told you what I would do. Hell, I've found new Motorcraft Alt's for $35 that way. -They include a regulator by the way.
Alright, I'll search for you..... - Here you go. How to isolate a Regulator vs Alternator problem.
http://www.bronek.org/sailing/zamind...leshooting.pdf
Old Jul 22, 2012 | 04:23 PM
JMC's Avatar
JMC
25 Year Member
ebay has alternators for $70.00. free shipping.
