Getting the "MORE" Lift bug
Old Jul 17, 2012 | 11:38 AM
Blue-02-2wd's Avatar
Originally Posted by Barrett
Just the lift for now, broke college kids can't afford all that at once..
Getting 2" up front, and getting my rear block taken out and replaced with a bigger anti-wrap block and an AAL. Hoping it looks fine with 35"s since I'm 2wd and sit lower than a 4wd would. Dropping it off at 9 on Thursday, should be done around 2 or 3
I think it will still look great with the 35's! Truck looks mean
Old Jul 17, 2012 | 11:51 AM
str8t six's Avatar
you dont think you will be too high above the tires with the coil spacer?
your SD was badass! how big were the tires on it?
Old Jul 17, 2012 | 11:58 AM
i was running 38 x 14.50's on on 16.5 x 12 weld super single 2's on her with 488 gears and arb air lockers front and rear. stage 2 injectors with a bigger lift pump and propane injection. Actually took that pick at silver lake was over 14" of lift it coulda cleared 44's easy. I think the coil spacer will put me at the same lift as Gator cause he's running a 7.5 fabtech and im running a 6.5 springtech.
Old Jul 17, 2012 | 01:32 PM
pizzaman711's Avatar
Gator will still have that extra inch on you, he has the coil spacer too iirc haha. But dang the trucks gonna look sick man once you put some more lift on it!
Old Jul 17, 2012 | 01:45 PM
I just hope the 37's won't rub..... I'm thinkin spring time for new tires now. I'll do the toyo m/t's again but in a 37 x 13.50 x 20.
