jet shift kit
Old Jul 12, 2012 | 07:15 AM
samirar's Avatar
jet shift kit
I found a jet shift kit on cl. And it is the shift kit that haves the two wires that connect up to the trans. The model number of the kit is 70704. I need some advice if I should get or not
Old Jul 12, 2012 | 09:27 AM
aussiekeeper's Avatar
Need a lot more clues than that, Bro.............we aren't mind readers.
Old Jul 12, 2012 | 10:15 AM
samirar's Avatar
I have a automatic trans with the 4r70w and the shift kit is made for a 94-03 Ford
Old Jul 12, 2012 | 11:07 AM
samirar's Avatar
this is the shift kit I'm talking about http://brunswick.craigslist.org/pts/3048486652.html
Old Jul 12, 2012 | 12:02 PM
That looks like the Banks line pressure box, only a different brand. It is not a cure, but a band aid for a problem that should be looked in to........The box raises the line pressure.
Old Jul 12, 2012 | 01:42 PM
samirar's Avatar
Would you recommend it if I have a programmer already and I have a canned & custom tune that I use. But mostly the canned tune
Old Jul 12, 2012 | 01:56 PM
Why were you considering this box? Are you looking for sharper shifting?
Old Jul 12, 2012 | 02:03 PM
samirar's Avatar
I wanted a little bit of sharper shifting. And something that will be able to chirp the tires
Old Jul 12, 2012 | 02:51 PM
Buxton91's Avatar
Talk to whoever does your tunes for you and tell them what you're wanting. They should be able to make a tune for you with more aggressive shifting.
Old Jul 12, 2012 | 03:01 PM
Alfredoleffew's Avatar
What are the benefits for a shift kit anyway?
Old Jul 12, 2012 | 03:29 PM
Have it done with the tuner, much safer...........
