Any ideas
Old Jun 16, 2012 | 04:01 PM
dmaul99's Avatar
Any ideas
I just replaced the drivers side coil pack on my 99 4.6L. Had a code 304 misfire on #4. After replacement engine seemed to run fine on test drive. I removed the neg battery terminal for about 15 minutes to reset code. Truck started but ran extremely rough so I shut it off. On restart it ran okay for about 30 seconds then died. It will not restart. Checked all fuses and relays. Any ideas?
Old Jun 16, 2012 | 04:51 PM
Red02FX4's Avatar
Quick switch you old coil back on .... what does it do then?
Old Jun 16, 2012 | 09:38 PM
Bluegrass's Avatar
You need to start all over again.
First, did you put the plug wires on the way they came off the old coil?
Cylinder 4 is the rear most on the passenger side.
No need for 15 min to reboot the computer. 1 min will do it.
Until you have something to go on it's just guessing.
Is there anything else you did?
Good luck.
