Truck Overheating - 2002 4.6L
Need Help! Truck overheating after being on the interstate for 400 miles of running regular temp, the temp increases dramatically when off the highway and stopped for gas. Water level fine. Fan replaced one year ago. Back on the highway, engine cools right back down when at speed.
Doesn't always increase in TEMP at slow down or stopped. Kinda stumped. Thanks for any help/advise.
Randy
Randy
Thanks for the responses. NO, I do not hear the loud roar. It does do that every now and then when I start the truck. I guess my 1 yr fan could certainly be defective. I'll RE-replace it. Thanks.
i could have swore it was overheating... but if his fan roars like he claims it does when he starts it id say it is ok. Am i right? because that would indicate the clutch system on the fan is still in tact. seldom do i hear my fan kick on when i am in the pastures checking cattle, and im driving through grass that reaches over my hood, cutting off air flow.
The fan clutch is heat sensitive. It WILL run and roar after startup, then cut out. It should cut back in when the temperature rises to a certain point.
When you are sitting and it's running hot, it DEFINITELY should be running and roaring.
